TalmageHolt
Mar 11, 2014Guide
SRX5308 Throughput Reduced with Firewall Rules
I will narrate the issue just so that it can be documented. I hope it can be passed along as far as it needs to be fully resolved. My Gigabit Fiber WAN is very stable and does not fluctuate. SRX5...
maier64
Nov 07, 2014Aspirant
But this is exacly whats not working.
I did some further tests:
Reset to default, empty configuration - Everythings okay.
Load settings with all rules disabled - still fine.
But as soon I do anything in the ruleset, no matter what, enable, delete etc. it's not working anymore.
From this moment on nothing helps, reboot with all rules disabled, settings restore, nothing.
If I reset to default alls fine until I do something with the rules.
Such a expensive router and such a crappy firmware.
Are we 2 the only ones with that problem?
