TalmageHolt
Mar 11, 2014Guide
SRX5308 Throughput Reduced with Firewall Rules
I will narrate the issue just so that it can be documented. I hope it can be passed along as far as it needs to be fully resolved. My Gigabit Fiber WAN is very stable and does not fluctuate. SRX5...
Nhellie
Dec 08, 2014Virtuoso
eram wrote: I had some issues with my SRX-5308 (Router rebooting with no reason ...)
So I've tried upgradging from firmware srx5308_v3.0.7-45 to srx5308_v4.3.1-22
After the good surprise that all my settings ( :confused: in fact a previous copy of oll my settings) has been reloded after upgrade, i had for the fist time the speed limit problem : WAN @ 300Mbs / LAN @ 100MBs
I've reseted the router to factory settings -> speed OK :)
Set some Firewall rules (simple stuff : 2 http; 2 https) -> OK :)
Rebooted -> Speed issue :(
Reloaded backup config (lots of rules) & Reboot :( no more luck
Disabled All firewall rules & Reboot :)
Re-validated rules (no reboot) :) still runnig at full speed
Trick worked but I don't feel secure ...
Have you contacted support to see if there is a beta or new FW to fix this issue?
