TalmageHolt
Mar 11, 2014Guide
SRX5308 Throughput Reduced with Firewall Rules
I will narrate the issue just so that it can be documented. I hope it can be passed along as far as it needs to be fully resolved. My Gigabit Fiber WAN is very stable and does not fluctuate. SRX5...
eram
Dec 14, 2014Novice
Nhellie26 wrote: Have you contacted support to see if there is a beta or new FW to fix this issue?
No, but reading the above comment, i'll also give a try to another brand.
We use 5 Netgear routers, we had issues and strange behaviors with all (SRX & FVX538 Dual Lan), and have equipped our customers with the same products ...
I don't think something like a router (no so complex) should require beta releases years after launch. That's the kind of stuff i'm expecting to work out of the box, without crashing, or having out of specs issues. I've replaced linux boxes by these smaller appliances for more simplicity.
