TalmageHolt
Mar 11, 2014Guide
SRX5308 Throughput Reduced with Firewall Rules
I will narrate the issue just so that it can be documented. I hope it can be passed along as far as it needs to be fully resolved. My Gigabit Fiber WAN is very stable and does not fluctuate.
SRX5308 Router Problem with LAN<--> WAN throughput. If the router is booted with any firewall rules enabled, throughput is limited to a rather jittery 95 - 120 Mbps down and under 100 Mbps Up. When booted with all firewall rules disabled and nothing else changed, the throughput is very solid and stable 850 - 930 Mbps down and 900 - 950 Mbps Up.
This problem is entirely dependent on the boot configuration having any firewall rules enabled. If the router is booted with any firewall rules enabled then the situation persists (after boot I cannot disable and then re-enable rules to fix it). If the router is booted with all firewall rules disabled then I can enable, disable, enable them without having the problem and it persists (throughput is as expected until there is another reboot). No other settings in the router affect the throughput issues.
I have experienced this issue with both firmware versions 4.3.0-19 and 4.3.1-22. I did not have the Gigabit WAN Connection before the 4.3.0-19 version. I have set the router back to manufacturer defaults and then restored settings from .cfg file and it has not changed the issue with either firmware versions. I have even restored the defaults and entirely set up all settings manually from scratch on each firmware revision. Nothing changed and it was many hours of wasted time.
This is an escalated issue that must have the “bug” resolved as fiber WAN Links can routinely be had over 100 Mbps
- NhellieVirtuosobeta FW v4.3.1-30 is supposed to fix this issue.
- maier64AspirantIs this FW already availlable ? Can't find it.
Or when is it supposed to be released? - NhellieVirtuoso
maier64 wrote: Is this FW already availlable ? Can't find it.
It is a beta FW, it is only given to customers that are experiencing the issue. You will have to contact support and tell them that you are affected.
http://support.netgear.com/general/contact/#tab-call - maier64AspirantHabe die Beta FW erhalten und eingespielt.
Leider haben sich die Ergebnisse sogar noch um 20% verschlechtert.
Sehr enttäuschend.
Werde wohl doch bei meinem neuen Cisco bleiben, dort gibt es keine Probleme. - maier64AspirantSorry, wrong language.
Tried the new FW but the results are not good.
Throughput is now even 20% lower than before.
Very disappointing.
It seems I have to stick to my new Cisco, no problems there. - NhellieVirtuoso
maier64 wrote: Sorry, wrong language.
Very disappointing.
Did you report back to support that the FW worsen the issue? Did you also try performing a factory default after updating btw? - maier64AspirantYes, I did report that to the support.
- NhellieVirtuosoHow about the factory reset? Did you try that as well?
- All,
A new firmware for SRX5308 has been released (4.3.2-7).
It seems to have resolved the issue with reduced throughput when booting with firewall rules enabled.
I can now boot router with all firewall rules enabled and get 900+ Mbps down and 920+ Mbps Up.
Seems to work flawlessly and has been up without issue over a week at several locations...
Anyone else have the issue resolved? - Hope Netgear Engineering gets feedback from the forum...
SRX5308 firmware 4.3.2-7 seems to have fixed the speed throughput when booting router with firewall rules enabled...
Now getting 900+ Mbps Up/Down throughput across router.
