steph762
Nov 06, 2012Aspirant
SRX5308 too slow to manage a 100MB fiber ?
I got a SRX5308 router load balancing a 20 MB ADSL with a 100 MB symetrical fiber connection. I've made so many test to finally think that it is the SRX5308 that is limiting the throughput to 35 MB a...
DaneA
Oct 27, 2015NETGEAR Employee Retired
Hi steph762,
I assume that you have update the firmware to v4.3.3-6. Have you factory reset the SRX5308 then reconfigure it from scratch?
DaneA
NETGEAR Community Team
steph762
Nov 02, 2015Aspirant
Thanks for your reply.
Yes I have again reset all my config to setup from scratch again and again.
But NO I'm not paid to be a beta tester. But I will be pleased to talk about that.
It's been almost ten times I have to test an upgrade and to reconfigure the same router from scratch.
New firmwares didn't give me back the bandwith capability that I've paid for.
- DaneANov 03, 2015NETGEAR Employee Retired
Hi steph762,
Are you still using firmware v4.3.3-6? Do you have firewall rules enabled on the SRX5308?
Let me share this old forum thread. Kindly read it then follow the steps suggested. Hope it works for your SRX5308.
DaneA
NETGEAR Community Team- steph762Nov 03, 2015Aspirant
No, I reverted to the old firmware, like I said before, because I've full bandwidth with it.
Yes I've firewall rules, it is just NAT and PAT rules.
I tried those rules with both firmware.
Hi steph762,
With regard to this, it would be best that you to contact NETGEAR Support then open a case about your concern. Let NETGEAR Support know about your experience. They might get logs from the SRX5308 using the latest firmware as well as with the current firmware you are using to analyze it and if possible, escalate it to the engineering team.
DaneA
