steph762
Nov 06, 2012Aspirant
SRX5308 too slow to manage a 100MB fiber ?
I got a SRX5308 router load balancing a 20 MB ADSL with a 100 MB symetrical fiber connection. I've made so many test to finally think that it is the SRX5308 that is limiting the throughput to 35 MB a...
DaneA
Nov 03, 2015NETGEAR Employee Retired
Hi steph762,
Are you still using firmware v4.3.3-6? Do you have firewall rules enabled on the SRX5308?
Let me share this old forum thread. Kindly read it then follow the steps suggested. Hope it works for your SRX5308.
DaneA
NETGEAR Community Team
steph762
Nov 03, 2015Aspirant
No, I reverted to the old firmware, like I said before, because I've full bandwidth with it.
Yes I've firewall rules, it is just NAT and PAT rules.
I tried those rules with both firmware.
- DaneANov 03, 2015NETGEAR Employee Retired
Hi steph762,
With regard to this, it would be best that you to contact NETGEAR Support then open a case about your concern. Let NETGEAR Support know about your experience. They might get logs from the SRX5308 using the latest firmware as well as with the current firmware you are using to analyze it and if possible, escalate it to the engineering team.
DaneA
