steph762
Nov 06, 2012Aspirant
SRX5308 too slow to manage a 100MB fiber ?
I got a SRX5308 router load balancing a 20 MB ADSL with a 100 MB symetrical fiber connection. I've made so many test to finally think that it is the SRX5308 that is limiting the throughput to 35 MB a...
steph762
Jan 03, 2013Aspirant
Just upgraded to 4.2.1 firmware. Yippee, problem almost solved.
I've been able to test just after reboot, 93 MB download and 45 MB upload !
A good progress.
A good progress.
steph762
Oct 19, 2015Aspirant
My fiber connection has been upgraded. 800 Mb/s download and 250 Mb/s upload. Verified connected directly to the box (847 download, 265 upload).
And the problem is still there. The SRX5308 should be able to manage 924 Mb/s (specifications).
The best I can test with the SRX5308 is 85 Mb/s download 95 Mb/s upload.
I confirm that I'm connected with Gigabit.
I have once again to downgrade the firmware to get back better results.
What happen with new firmware. There is so many bugs not corrected since so long.
Should I be a beta user all the live of this product ?
- DaneAOct 27, 2015NETGEAR Employee Retired
Hi steph762,
I assume that you have update the firmware to v4.3.3-6. Have you factory reset the SRX5308 then reconfigure it from scratch?
DaneA
NETGEAR Community Team
- steph762Nov 02, 2015Aspirant
Thanks for your reply.
Yes I have again reset all my config to setup from scratch again and again.
But NO I'm not paid to be a beta tester. But I will be pleased to talk about that.
It's been almost ten times I have to test an upgrade and to reconfigure the same router from scratch.
New firmwares didn't give me back the bandwith capability that I've paid for.
- DaneANov 03, 2015NETGEAR Employee Retired
Hi steph762,
Are you still using firmware v4.3.3-6? Do you have firewall rules enabled on the SRX5308?
Let me share this old forum thread. Kindly read it then follow the steps suggested. Hope it works for your SRX5308.
DaneA
