externaluse
Feb 09, 2017Aspirant
SRX5308 Traffic meter - what the heck?
Pictures speak a thousand words.
This was open in a tab on an SRX5308 running FW 4.3.4-2, the Tab was refreshed periodically for a while. The traffic made sense, and kept growing over time within expected amounts.
At one point coming back from being logged out due to inactivity (but not for the first time), this is the same screen (yes, on the same router) after logging back in:
OK... We transfer way more data then that per day. The reset time hasn't changed, it has not been reset or otherwise fiddled with! So if in doubt, reboot. Guess what the screen looks like now:
Anyone noticing how I managed to time it so accurately that I got 2048/4096/512? Those numbers ring any bells?
Something is completely broken in this. All I want to know is how much traffic I send, and which machine(s) generate the most.
If anyone could help with a clever idea that'd be great! Thank you!
- train_wreckLuminary
Yes, I see the same thing on an FVS336Gv3. If I had to guess, the Netgear is incapable of showing data amounts past a certain number, and either resets & begins counting again or just shows those powers-of-2 (which I have also seen). My theory would be that the firmware is using a 32-bit integer variable to store the data amounts, and is overflowing when the value is maxed out, but of couse I don't have firmware source access and so can't be certain.
Seeing as there hasn't been a substantial feature update to any of the current FVS line in a number of years..... I wouldn't hold your breath for a fix.
- SamirDProdigy
And consider trying an older version of the firmware as this might have been broken in newer firmware releases. If this is a critical feature for your usage, I would run the older firmware. The firmware versions are more like 'feature sets' than sequential anyways.
