ronealwa's avatar
Mar 11, 2020
Orbi Traffic Meter stopped working
In the last several days the Traffic Meter on my Netgear Orbi system mysteriously stopped working. All entries reverted to zero even though I have traffic flowing every day.
I googled the issue and found a solution about turning of the "adjust for daylight savings time" option under the NTP Settings under the Advanced>Administration>NTP Settings.
When I turned this off and saved, magically the Traffic Meter readings came back and everything seems to be working fine now except that my "Orbi clock" is now off by 1 hour because the Adjust for DST option has been turned off.
Is this a known bug and is Netgear actively working to fix it?
Thanks.
  • Maybe I'm missing something but there seems to be a simple work-around for this.
    Turn off DST and then select a time zone that gives you the correct time. That will provide traffic and the correct time. Come November when the time changes back, you can just adjust your time zone back to the correct zone for your location.
  • FURRYe38's avatar
  • Anonymous's avatar
    Anonymous
    Thanks.
    so this has been an issue for 2 years and there is still no fix?
    https://community.netgear.com/t5/Orbi/Orbi-Traffic-Meter-Issue/m-p/1499209
    https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Traffic-meter-DAYLIGHT-SAVING-TIME-BUG-R7800/m-p/1525687#M86499
  • CrimpOn's avatar
    CrimpOn
    Interesting report.  Have you tried checking the Daylight Saving Time box again to see if Traffic Meter keeps working?
    I have watched this forum for two years and this is the first report about this I remember seeing.  My guess is, "No. This is not a 'known bug' and Netgear is not actively working to fix it."  Netgear appears not to be fixing a number of really serious issues that affect many customers and prompt pretty angry comments on the forum.  If there is a priority list, my guess is investigating an issue like this will be FAR down the list.
    Hope this doesn't come across as too negative.  I am one of those who are really happy with the performance of my Orbi and glad I bought it.
    • ronealwa's avatar
      ronealwa
      Star
      I did try turning the DST option back on and when I did, the traffic meter reverted to all zeroes again. So I can reproduce the problem consistently.
      Oh well, I am just happy that I got a solution that got the traffic meter back working correctly. I can live with the clock being off an hour...until the fall when we go back off DST...lol
      • CrimpOn's avatar
        CrimpOn
        Thanks for the report. I should have checked my own Orbi before responding.  "Funniest thing", MY RBR50 Traffic Meter is also "zeroed out."  When I turn it off and download 100mb of files, nothing shows.  When I turn it back on again and download files, nothing slows.
        What fun!
