don_daniel
Oct 27, 2016Tutor
srx5308 upnp activated but my qnap cannot assign its ports
Hi there i just installed my srx5308 and connected all devises... now , my qnap server has the function to set the ports (UPNP) itself but that requires a router that is supporting this... the srx53...
DaneA
Oct 27, 2016NETGEAR Employee Retired
Hi don_daniel,
Kindly answer the questions below:
a. Is the QNAP server directly connected to the SRX5308?
b. It is possible that port forwarding is required. What are the ports that are needed to be opened for the QNAP server?
c. What is the current firmware version of the SRX5308?
DaneA
NETGEAR Community Team
- don_danielOct 27, 2016Tutor
hi
i have 2 QNAP.s ... one is directly linked to the srx5308 and the other one has a prosave managed switch in between. ...
it looks like sometimes it finds the upnp and then again not....
i have tons of port forwarding that I need
i am using 4.3.4-2
by the way... where do I have an overview of all the IP addresses currently used in my LAN network? I couldn't find it so far...
- DaneAOct 30, 2016NETGEAR Employee Retired
Hi don_daniel,
About port forwarding on the SRX5308, kindly read pages 140-145, 149-151 and 164-168 of the SRX5308 reference manual here.
On the web-GUI of the SRX5308, go to Network Configuration > LAN Settings > LAN Groups to check the overview of all the IP address currently used in your LAN network. For more information, kindly read pages 97-98 of the SRX5308 reference manual.
DaneA
- don_danielOct 30, 2016Tutor
hi
thank you for the statements out of the manual. I am actually not referring to the manual settings that are posted in these articles.
i am referring to the UPNP function that the firewall supports (as of page 199 explained).
I have several NAS and a server that are settings the ports they require automatically... if the firewall is supporting it. according the above description, the srx5308 does, in theory at least..
