don_daniel
Oct 27, 2016Tutor
srx5308 upnp activated but my qnap cannot assign its ports
Hi there i just installed my srx5308 and connected all devises... now , my qnap server has the function to set the ports (UPNP) itself but that requires a router that is supporting this... the srx53...
DaneA
Nov 03, 2016NETGEAR Employee Retired
Hi don_daniel,
From what you have mentioned, it is impossible to know which is at fault and why is it after 30-60 minutes the port mapping is removed and is re-scanned.
With regard to your question “it seems to me that the SRX5308 periodical uPNP re-scan is somehow throwing out all current port settings... is there any setting on the SRX5308 that I can tweak to have a stable port forwarding using UPNP?” – the answer here is no, as we can only set the Advertisement period and Time to Live, but not the periodical re-scan time.
If ever you could possibly gather the dbg logs after the issue appears: so the QNAP is found and UPnP opens the ports, then they are lost, and then opened again, kindly take the dbg logs and attach it here on this forum thread.
Furthermore, it would also be worthwhile for you to kindly check up with QNAP Support Team as well if they can verify the NAS is not causing the issue. Just to be clear, we are not trying to put the blame on the QNAP NAS, we just need to get their perspective on the issue as it is too hard to know which is causing the issue from the information we have.
DaneA
NETGEAR Community Team
don_daniel
Nov 03, 2016Tutor
yes indeed. i have contacted qnap too... lets see if there is somithing coming back from them
regarding the log.. what kind of settings would i have to set to properly log upnp activities?
and... if that is not going to be solved fast... where can I set the ports myself? any rules to follow?
I assume the outbound ports are open anyway.. so I would only need to configure the inbound ports? is that correct? where is that done? on the port triggering tab? might e a problem as I have ports below 1025 which is the lowest port I can set there in the port triggering section
just had such an 'outage' again! and what I can say is that it is blocking all internet access as a whole! I don't get to the pages outside ... for about 2 minutes!! so, maybe the UPNP settings are just a symptom to the probem that the srx5308 is not available for 2 minutes (sounds like it is rebooting??)
- DaneANov 03, 2016NETGEAR Employee Retired
Hi don_daniel,
I suggest that we get first the dbg logs from the SRX5308 for it to be analyzed before we configure anything on the SRX5308 such as port triggering. Here are the steps to get the dbg logs from the SRX5308:
a. Connect a PC directly to the SRX5308.
b. Open a browser like Chrome or Firefox.
c. At the address bar, type https://LAN_IP_address_of_the_SRX5308/scgi-bin/dbglog.cgi (for example: https://192.168.1.1/scgi-bin/dbglog.cgi).
d. Press Enter and it will automatically download the dbg logs.
DaneA
- don_danielNov 03, 2016Tutor
sure. log is ready.... but it seems i can only upload images?? no files??
it is a tgz zipped file with lots of additional files in it
Hi don_daniel,
You may use http://wikisend.com/ to upload the dbg logs then kindly post the download link when you reply back so that I can download it here on my end.
DaneA
ok. here we go
Hi don_daniel,
I have already forwarded the dbg logs from your SRX5308 to be analyzed. I will post here the findings as soon as I receive a feedback.
DaneA
- don_danielNov 04, 2016Tutor
hello
i did a hard reset on the firewall and it seems like this has solved my issue... since 24 hours no such aborts anymore..
lets cross fingersè!!
- don_danielNov 05, 2016Tutor
well..was too enthusiastic...
problems are back!
would be great to analyise the file that I have provided ... thanks!
and something to add... I did enter recently port triggering entries (3 lines)... can that be the root cause of the issues I have?
- DaneANov 07, 2016NETGEAR Employee Retired
Hi don_daniel,
I just got a feedback from a higher tier of NETGEAR Support who reviewed the dbg logs. There is no trace found of having an issue with UPnP from the SRX5308.
To further isolate the problem, kindly add another device which has UPnP capability (which is not one of the QNAP NAS) and see if a separate device is seeing the same issue with UPnP table being cleared and needing to re-scan. Kindly get the dbg logs as well to be analyzed.
DaneA
- don_danielNov 07, 2016Tutor
hi
thank you very much for communicating to the netgear support.
I have meanwhile found out that the upnp setings/unavailability of the srx5308 happens only when the I add port triggering ruls! when I remove them, I dont get any problems anymore...
i have now adde lan wan rules and it also works without problems... so generally speaking my problem I could get around by using a work around.. still, I have this srx5308 and do expect that all features work ... also upnp settings and port triggering...
and just a question for clarification... do i need upnp enabled as well as port forwarding/triggering when adding ddns to the SRX5308? is it not the purpose of the ddns to let pass communication in/outbound which would make the port settings obsolete?
- DaneANov 08, 2016NETGEAR Employee Retired
Hi don_daniel,
You do not need to enable UPnP or configure port forwarding/triggering when adding DDNS to the SRX5308. Also, DDNS has no purpose to let pass communication in/outbound which would make the port settings obsolete.
DaneA
- don_danielNov 08, 2016Tutor
so, did I get you correctly, that by adding the ddns to the router, i can remove all port settings including disabling the upnp function...
I then would access my servers and all other applications that are working with ports by using the DDNS address and the port number ...
how is that managed if I am within the LAN / not over WAN... and for example I want to use the TELNET to acces a server... I cannot use the DDNS within the LAN but would rather use the internal IP address:port number... is that possible without UPNP/Port triggering/forwarding enabled?
Hi don_daniel,
For example, your DDNS is don_daniel.com and you will need port 8080 to access the NAS from outside your network. You will need open port 8080 and point it to the LAN IP Address of the NAS. Then, to access the NAS outside your network, you will enter https://don_daniel.com/8080 on the address bar of a browser.
If you are within your LAN, you do not need DDNS to access the server via telnet. Port forwarding, port triggering and UPnP are not needed as well. Just simply open hyperterminal or PuTTy then open a telnet session to the server.
DaneA
ok.. i am apparantly not smart enough to understand your input...
the bold sentence is the one that I do not understand... I need to open a port?? so I still would need the upnp and port triggering settings or what do you mean with open a port..??=
Hi don_daniel,
What I mean by "You will need open port 8080" is you will need to configure port forwarding.
DaneA
aha.ll well then I am where I was before. thanks
- don_danielNov 10, 2016Tutor
lets then get back to my initial issue...
... port triggering (and maybe together with upnp activated) does cause outages at my router..!
I remove port triggering and the upnp works fine and no outages happen anymore..
I could of course use lan to wan port settings instead port triggering.. still.. the above setting I paid for and I'd like to have it fully working..! - DaneANov 13, 2016NETGEAR Employee Retired
Hi don_daniel,
Were you able to add another device which has UPnP capability (which is not one of the QNAP NAS) and see if a separate device is seeing the same issue with UPnP table being cleared and needing to re-scan in order to isolate the problem? Kindly get the dbg logs as well to be analyzed.
Since you have also raise your concern to the QNAP Support Team, may we know what are their findings?
DaneA
- don_danielNov 13, 2016Tutor
hi
I have no other devices with UPNP settings in my LAN. and the problem is not the UPNP of the QNAP NAS as they work fine as long as the port triggering is not set... so the problem is actually the port triggering that I had set... i removed them a week ago and all, including upnp is working fine!
the issue seems to be the port triggering.
qnap has checkt the qnap log an d has found the same conclusion..
regards
dondaniel
- DaneANov 14, 2016NETGEAR Employee Retired
Hi don_daniel,
You mentioned that port triggering causes outages on the SRX5308. Kindly post a screenshot of the port triggering you have configured.
DaneA
- don_danielNov 14, 2016Tutor
for obvious reasons I cannot send a screenshot (have removed the settings). but the following I did set as port trigger rules
Name Enable Protocol Outgoing Ports Incoming Ports Action
Start Port End Port Start Port End Port
1 VM_QNAPXXX Yes TCP 8088 8088 8088 8088 Edit
2 VM_QNAPYYY Yes TCP 8089 8089 8089 8089 Edit
3 VM_QNAPZZZ Yes TCP 3388 3388 3388 3388 Edit - DaneAJan 01, 2017NETGEAR Employee Retired
I apologize for the late reply. I got a feedback recently from the higher tier of NETGEAR Support regarding your concern. According to them, it would be best that you open an online case with NETGEAR Support about your concern for further investigation. Kindly state your concern as well as attach the logs and screenshots on the online case.
DaneA
- don_danielJan 02, 2017Tutor
well danea
i did that already some time ago.. and since the netgear I bought as a 2nd hand, netgear online did refuse any help and support and was directing me to the community...
and now you tell me that I can't get any help here but need to report to netgear support..? seems there is a catch22 which is not going to help me in any way...
regards
dondaniel
- DaneAJan 04, 2017NETGEAR Employee Retired
I apologize if you felt that way. :( I've been doing the best that I can to help that is why I make time to consult your concern and follow-up on it to higher tier of NETGEAR Support even though I am not part of NETGEAR Support team.
It seems to me that the engineering team should get involved in your concern that is why it was advised to open an online case with NETGEAR Support for further investigation.
Again, I am sorry for this inconvenience. Hope that someone here on the community (who has same concerns as yours that got resolved) could reply on this forum thread and share his/her experience.
DaneA
