don_daniel
Oct 27, 2016Tutor
srx5308 upnp activated but my qnap cannot assign its ports
Hi there i just installed my srx5308 and connected all devises... now , my qnap server has the function to set the ports (UPNP) itself but that requires a router that is supporting this... the srx53...
DaneA
Nov 13, 2016NETGEAR Employee Retired
Hi don_daniel,
Were you able to add another device which has UPnP capability (which is not one of the QNAP NAS) and see if a separate device is seeing the same issue with UPnP table being cleared and needing to re-scan in order to isolate the problem? Kindly get the dbg logs as well to be analyzed.
Since you have also raise your concern to the QNAP Support Team, may we know what are their findings?
DaneA
NETGEAR Community Team
don_daniel
Nov 13, 2016Tutor
hi
I have no other devices with UPNP settings in my LAN. and the problem is not the UPNP of the QNAP NAS as they work fine as long as the port triggering is not set... so the problem is actually the port triggering that I had set... i removed them a week ago and all, including upnp is working fine!
the issue seems to be the port triggering.
qnap has checkt the qnap log an d has found the same conclusion..
regards
dondaniel
