PeterBroersen
Feb 08, 2017Aspirant
SRX5308 VPN to FVS318v3
Does anybody know if it is possible to set up a VPN connection between a SRX5308 and a FVS318v3? I have succesfully connected 2 FVS318v3's with VPN, but now 1 of them needs to be replaced because th...
PeterBroersen
Mar 10, 2017Aspirant
Hello Brent,
Can you send me screenshots of your configuration? Or maybe you can help me, if I send my screenshots to you?
Did you open any ports on your internetmodem?
Any help is welcome.
BrentHarsh
Jul 20, 2017Aspirant
PeterBroersen wrote:Hello Brent,
Hi Peter, sorry for the very long delay; I rarely check back and missed this note. Have you solved your problems with the 5308? If you want to send a screenshot of your configs I could try to compare to my setup. Hopefully though, you're long since sorted out.
