bruceUK
Nov 16, 2016Aspirant
SRX5308 Wan access to webserver
Hi, I am having difficulty setting up access to a SecuritySpy webserver for my cameras from the internet for remote viewing. I'm sure i must be missing something - but i cant see what! The se...
- Nov 18, 2016
Hi bruceUK,
See if there will be any improvements after the firmware update. I don't see a reason why they would not work.
Thanks,
JohnRo
Nov 16, 2016NETGEAR Employee Retired
Hi bruceUK,
Welcome to the community!
I'd like to ask a few questions for us to identify the issue, see below:
- Are the cameras accessible locally?
- Are you using a modem or a gateway(modem/router)?
- What is the firmware version of the SRX5308?
- Are ports 8000 and 8001 defined on the cameras?
Looking forward to your response.
Thanks,
- bruceUKNov 16, 2016Aspirant
Hi,
Thanks for getting back to me, in answer to your questions -
1. Yes, The cameras are all accessible locally. They connect to the SecuritySpy server and all cameras can be viewed through the SecuritySpy built in webserver by http://192.168.1.101:8000 or https://192.168.1.101:8001
2. No, I am using a wireless internet connection that connect directly to the SRX5308 via a CAT5 cable, and the SRX5308 handles the authenification to the service provider
3. 4.3.3-5
4. They are the ports used to accces the SecuritySpy webserver
Thanks in advance
Bruce
- JohnRoNov 16, 2016NETGEAR Employee Retired
Hi bruceUK,
Regarding number 2, does the wireless internet connection use 4G/LTE? Does it give a public IP to the SRX?
Thanks,
Hi,
Heres some more info here -
http://www.thinkingwisp.co.uk/how-it-works/
Essentially it works the same as a cable broadband connnection - albeit with wireless between the mast and my receiver, which then connects to the SRX via CAT5
and yes it does provide a public IP address to the SRX
Regards
Bruce
