Hamlet
Oct 30, 2017Aspirant
SRX5308, wifi dropouts
I have an SRX5308 set up with an 2 Wans, an ADSL connection and a 4G wireless. I use a Nighthawk R7000, AC1900 as an access point at my house and an AP731 at my shed approximately 150meters away. O...
DaneA
Oct 31, 2017NETGEAR Employee Retired
Hi Hamlet,
Let us first check the wired connection to the internet in order to isolate the problem. Here are the steps below:
1. Connect a PC/laptop directly to any LAN port of the SRX5308. Make sure to disable the built-in wireless adapter of the PC/laptop.
2. Check if the PC/laptop is able to acquire a valid LAN IP address to its wired adapter.
3. Open a browser and observe if you are able to surf the internet just fine while the PC/laptop is directly connected to the SRX5308.
Are you able to go online just fine via a wired connection through the SRX5308?
DaneA
NETGEAR Community Team
- HamletOct 31, 2017Aspirant
As mentioned in my post.... System works fine when hard-wired
- DaneANov 01, 2017NETGEAR Employee Retired
Thanks for the feedback. Since the wired connection is fine through the SRX5308, then the Nighthawk R7000 set as the access point should be checked. I suggest you to post your concern about the WiFi dropouts in the Nighthawk WiFi routers here. You may want to start your post by doing some troubleshooting steps like changing the wireless channel then indicate what is the result.
DaneA
