tstrike
Aug 03, 2015Aspirant
SRXN 3205 No ethernet but I got WiFi #25533784
Hi adit and June,
Its been a long long time guys and I hope you both are still around.
Learned today that my trusty 3205 is EOL (man .....!)
I had a bad power outage with a transfor...
JohnRo
Aug 03, 2015NETGEAR Employee Retired
Hello tstrike,
Good day!
I have checked your profile on your system and you already have a support ticket. I am adding the support number to this post. Upon checking, the device is still covered by the lifetime warranty and is valid for replacement. Please perform this reset procedure below:
NOTE: You will have to press the reset button (Factory Defaults) for a total of 90 seconds.
1. While the unit is on, push and hold the reset button for 30 seconds.
2. Continue holding the reset button and turn off the unit (by unplugging the power cable). Do this for another 30 seconds.
3. Turn on the unit (by plugging the power cable back) , continue holding the power button for 30 more seconds.
4. Let the router boot completely.
5. Access UI and test Ethernet and wireless connectivity.
Once you have performed this, and still has the same issue please contact support and refer to this forum link. You should get a replacement.
Hope this helps. I'll look forward to your response.
Thanks,
- tstrikeAug 04, 2015Aspirant
Working on this now.
After following the directions for a power reset, my router is now COMPLETELY unusable!!! It is stuck in a reboot loop continously!!!
- aditAug 04, 2015Mentor
More than likely it is bricked.
I don't recall if that unti has a serial port but if so it may be recoverable that way.
