dysonp
May 12, 2012Aspirant
Srxn 3205
I was using a DG 834 with my SRXN3205 but I have recently changed to BT Infinity so now I have to use their modem instead of my DG834. Everything works apart from my VPN. When I try and connect via ...
jmizoguchi
May 12, 2012Virtuoso
dysonp wrote: Sorry but I still don't understand what you are saying. *I had the
same setup before I changed ISP and it worked so *I don't understand
why it would not work now.
check the WAN and it is public IP or not.. you just assuming so I wouldn't know
it's obvious something has changed
