toddkrein's avatar
toddkrein
Follower
Jul 18, 2011
SRXN3205 and static routes
Good People:
I'm using an SRXN3205 behind a motorola cable modem bridge. My ISP has given me one static IP, and two dynamic IPs. I need the static IP for the VPN router (FVS114) that my company has supplied to me, and I'm letting the 3205 pick up one of the dynamic IPs.
Essentially (pls ignore the actual numbers), my dynamic IP is (say) 74.1.2.3, and I'm using the 192.168.200.x subnet behind it, with the 3205 at 192.168.200.1. All of that is goodness and light, working fine.
The static IP they gave me was 68.4.5.6, not even close to the same subnet. OK, i thought, I'll just pop in a static IP address, and all will be fine. (A fixed 1-1 NAT would have worked as well, but it doesn't look like I can do that with the 3205).
So I tried setting a route:
Active
dest: 68.4.5.6
Mask: 255.255.255.255
Inf: LAN
GW: 192.168.200.1
Needless to say, it isn't working.
If I set the GW to 68.4.5.6, I get a cryptic "Command Error".
I'm assuming that interface means the port that is connected to the destination device (in this case it's hanging off the LAN). I would have throught that the GW would have been 68.4.5.6, since there is a direct connection to the VPN gateway box.
Can someone help clarify this for me?
Thanks!
1 Reply
  • I would use inbound rules with ANY to specific IP for FVS will be used , you will able to assign wan IP in the inbound rules
    or classical routing but I don't think you want that under WAN section of the router
ProSupport for Business
