H3llGhost
Oct 08, 2011Aspirant
SRXN3205 No internet for any clients
Hello, I am facing the problem, that my clients losing the internet access after a short time. The WAN Status is always connected and I can lookup all domains, but I don't get any data to my clie...
jmizoguchi
Oct 08, 2011Virtuoso
H3llGhost wrote: Hmm ... Because there is no edit function, I have to write a double post, sorry.
I have tested the SSL-VPN connection and found out, that the internet access is working fine from the connected client. :)
In the same time I tested the internet access on the clients, but it doesn't work.
It is curious.
SPLIT tunnel uses local internet (remote end)
FULL tunnel uses ALL the traffic including the internet goes via SSL VPN
