H3llGhost
Oct 08, 2011Aspirant
SRXN3205 No internet for any clients
Hello, I am facing the problem, that my clients losing the internet access after a short time. The WAN Status is always connected and I can lookup all domains, but I don't get any data to my clie...
jmizoguchi
Oct 08, 2011Virtuoso
Yes I know (it stands in the manual ), but it doesn't explain why clients (local), can't access the internet.
The solution was to reset the router and know all works fine.
you need to make sure DNS section in SSL-VPN setting is correctly entered
