H3llGhost
Oct 08, 2011Aspirant
SRXN3205 No internet for any clients
Hello, I am facing the problem, that my clients losing the internet access after a short time. The WAN Status is always connected and I can lookup all domains, but I don't get any data to my clie...
H3llGhost
Daedalus01 wrote: And you've turned data plan off on the smartphone correct? I know that on mine, if the WIFI is down, it will revert to using the phones data plan.
WiFi is disabled, so the computer uses my data plan and connect over the internet with an external ip to my router. :)
