H3llGhost
Oct 08, 2011Aspirant
SRXN3205 No internet for any clients
Hello,
I am facing the problem, that my clients losing the internet access after a short time.
The WAN Status is always connected and I can lookup all domains, but I don't get any data to my clients f.e. ping doesn't work any longer, etc.
What can I do?
- H3llGhostAspirant
Daedalus01 wrote: And you've turned data plan off on the smartphone correct? I know that on mine, if the WIFI is down, it will revert to using the phones data plan.
WiFi is disabled, so the computer uses my data plan and connect over the internet with an external ip to my router. :) - jmizoguchiVirtuosofor internet traffic behind the 3205 issues then try placing ISP DNS to one of the PC's network properties. and see
- H3llGhostAspirantI have tried it with disabling the DNS Proxy, which means that the ISP DNS is transferred with the DHCP lease, but it hadn't any effect. traceroute shows that the traffic stopped at the router.
- jmizoguchiVirtuosoall devices or just one out so many?
- H3llGhostAspirantA few devices was tested without success.
- jmizoguchiVirtuosothis is still with VDSL broadband?
- H3llGhostAspirantYes with the VDSL broadband. :)
- jmizoguchiVirtuosohow are you setting with VDSL and SRXN..
VDSL require PPP login or not? - H3llGhostAspirantVDSL doesn't require any authentication. The connection type is DHCP.
- jmizoguchiVirtuosoassuming the WAN if srxn have public IP (dynamic IP)?
