smmahoney
Feb 24, 2013Aspirant
SRXN3205 troubleshooting
Windows 7/AT&T/FastAccess Business DSL 3M
We have problems with our internet being slow. Ive isolated the DSL modem and the traffic is within specification. I enabled traffic meter on the netgear router and it is showing that excessive email traffic (> 2GB per day) is being transmitted outbound (even when no one is there). I enabled logging and cannot find that traffic in the log. I attempted to capture packets but I cannot open the cap file to review. If the traffic metering is accurate then it will explain the slow upstream we are getting. How can I determine where this traffic is comming from using the SRXN3205 product?
Thank you
Thank you
- jmizoguchiVirtuosoDo you shut all computer down and you are seeing massive usage of email traffic?
- aditMentorDo you have an email server on the LAN?
- smmahoneyAspirantAbout 7 PC's on a peer-to-peer.
Machines are generally left on - I'd have to ask if they would turn them off at close of business to test.
No email server on LAN. - jmizoguchiVirtuoso
I would do "mandatory" shut down at the end of the day observe the issues. - smmahoneyAspirant
jmizoguchi wrote: I would do "mandatory" shut down at the end of the day observe the issues.
I will ask for a shutdown.
In the meantime, can you tell me in your expereince if the traffic meter is accurate? I've let this run for > than full day now and the avg is 6028MB per day outgoing email traffic (incoming is 300).
I know that is not work product because with that growth rate the file server volumes would be filled already. - jmizoguchiVirtuosoI think your best bet is to shutdown to see the changes. I hope you do.
If you don't have email server of your own then something is causing to move traffic.
I personally don't measure on mine with UTM 25 I use - smmahoneyAspirantok - so I did a shutdown and traffic subsided.
Once they were all back on I saw traffic again.
I created new firewall rules to allow all LAN->WAN traffic and log entries.
This let me see all of the traffic.
From there I was able to decern that there was significant traffic attempts on arbitray ports to many foriegn countries from a specific workstation.
I believe one of the machines may be part of a bot net.
I will research futher and scan the suspect machine but I think the mystery is solved.
thanks for your assistance. - jmizoguchiVirtuososounds like pc got adware/malware etc... all those good stuff :D
