rdsn
Jul 23, 2014Aspirant
SSL Endpoint UTM150
Hi I am trying to have a UTM150 act as an endpoint for an imcoming HTTPS site.
ie
Client -> UTM150 -> WebServer
|------SSL-----------||-----HTTP-----|
I have a number of existing SSL certificates but I don't see anywhere I can add these to the firewall?
Can anyone please assist?
Regards
RN
ie
Regards
RN
- aditMentorUTM Forums are here: http://forums.prosecure.netgear.com/index.php You need to install the cert on the server and forward via a Rule the HTTPS (443) service to the LAN IP of the server.
- rdsnAspirantSo the UTM will not act as an endpoint for https/SSL then? Very strange design as it is marketed as a enterprise product. :confused:
Thanks for your reply - jmizoguchiVirtuosoUTM only does SSL-VPN(only certificate is SSL-VPN needs) so it requires to to put your own certificate on web server side
- aditMentor
Are you trying to use the cert for SSL VPN or just for the webserver? Is the website public or private? The UTM can use that cert for SSL VPN/Remote Management. It is only a HTTPS (using 443) endpoint when Remote Management is left on the default port of 443 (most switch it to a port in the 8000-8100 range).rdsn wrote: So the UTM will not act as an endpoint for https/SSL then? Very strange design as it is marketed as a enterprise product. :confused: Thanks for your reply
