mdldes
Nov 29, 2018Follower
Suggested replacements for old SRXN3205
We have very tired SRXN3205, which is finally failing.
I am looking for suggestions for replacment, specifically it would be great if I could save the set up file from this unit and load it into th...
JohnC_V
Nov 30, 2018NETGEAR Employee Retired
Hi mdldes,
Welcome to our community! :)
Unfortunately, NETGEAR stopped producing firewalls. But you may still check our new Insight Instant VPN Router(BR500) if it will suffice your needs.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
