ssgtweasel
Dec 06, 2016Guide
Updated cablemodem speeds (100/10) however SRX5308 can only do (75/6) ?
Updated cablemodem speeds (100/10) however SRX5308 can only do (75/6) I've been running around 70mb down and 6mb up cablemodem was just upgraded to 100mb and 10 up connecting directly to SB6120 re...
- Dec 06, 2016
Update
reviewed my settings and noticed my wan1 was set to 75mps.
changed my ISP connection to 100mb up and 1gbps to down
changed from autosense to 1000 Full
saved and rebooted
getting around 93 down and over 10up
fixed my issues
sharing in case somebody else may need a little help
ssgtweasel
Dec 06, 2016Guide
Update
saved and rebooted
fixed my issues
- SamirDDec 17, 2016Prodigy
Glad your solution worked. I've been eyeing the SRX and even found one in the CDW outlet at one point for only $150, but didn't jump on it (should have). Seems like a very good unit for multi-wan and fast links.
