OneKey's avatar
OneKey
Follower
Feb 06, 2025
Use PR60X for firewall
Dear Netgear Support Team, Hello, I need to set up a small-scale network and would like to use your networking devices for this purpose. I am reaching out to confirm whether the following configura...
  • op3c's avatar
    Feb 07, 2025
    The network setup will work fine and speed should be good.
    PR60X has firewall and traffic rule support, but it is not UTM or NGFW, if you need comprehensive security solution, PR60X is not currently supporting it.
ProSupport for Business
