Stinky_W_Teats
Sep 16, 2020Aspirant
UTM5 firmware update issues
hi, I have a UTM5 that has not been updated in a while (shame on me), but when I went to do so now, I ran into issues: - I first tried to use the Query option under Firware Download to check for t...
- Sep 18, 2020
To summarize the solution: The UTM5 can not be upgraded to the last firmware.
I totally understand the decision not to offer a maintenance contract. But at least let people install the latest firmware that is downloadable from the Netgear site so they can continue to use what they paid for. Remove the restriction in the admin console - this is not a technical constraint; it seems to be more of a business model thing. The hardware works perfectly fine. But by preventing us from updating the software they have effectively rendered the hardware useless.
So I am looking at the Firewalla Gold to replace the UTM5. No subscription fee for signature updates, so hopefully they won't administratively kill their HW the way Netgear did with the UTM5.
JohnC_V
Sep 17, 2020NETGEAR Employee Retired
Welcome to our community! :)
My apologies. Unfortunately, UTM firewalls are already EOL and their maintenance license can no longer be purchased.
John
NETGEAR Community Team
Stinky_W_Teats
Sep 17, 2020Aspirant
Thanks for the reply John.
The question is: how can i upgrade the firmware? It is currently at 1.x and i downloaded the 3.x last version form the Netgear website. Just need to be able to upload it to the UTM5.
- JohnC_VSep 17, 2020NETGEAR Employee Retired
You may need a maintenance license in order for you to upgrade the firmware of your UTM5. Sadly, it was discontinued.
John
- Stinky_W_TeatsSep 17, 2020Aspirant
Thansk John. I will interpret that as you DO need a maintenance license, rather than you MAY need it. So it is basically dead at this point.
- Stinky_W_TeatsSep 18, 2020Aspirant
