Emy77
May 03, 2017Aspirant
View active connections
Hi everyone, how do I see all the active connections on my router ?? FVS318N Thank you Emy
Dan_Z
May 04, 2017NETGEAR Expert
Hi Emy,
Welcome to the community!
On FVS318N,can see active users under Monitoring->Active Users,VPN connection status under "VPN->Connection Status".
Thanks.
Emy77
May 04, 2017Aspirant
For VPNs and Active user (Which have logon access to the router) .... and for local connections LAN and WiFi?
Thank
- DaneAMay 08, 2017NETGEAR Employee Retired
To check what the devices that are currently connected via LAN and wireless, access the web-GUI of the FVS318N then go to Network Configuration > LAN Setup > LAN Groups. Kindly read pages 68-72 of the FVS318N reference manual here.
DaneA
NETGEAR Community Team- Emy77May 08, 2017Aspirant
Thank youuu. :smileywink::smileyhappy:
Emiliano
- Emy77May 11, 2017Aspirant
Hi, just another doubt ... on this page I see ARP Table, but I do not see the active links at that time! If I rename "unknown" in the name of the connected device "Smartphone" (for example), this always stays in the table even when not connected!
