deanwatson
Dec 11, 2017Aspirant
VPN Access from different LAN segment.
I have a working IPSec VPN to a remote site, that requires a configuration with a single IP Address at my end. I want to be able to access the host sytems at the remote site from a number of devices,...
DaneA
Dec 17, 2017NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
- deanwatsonDec 19, 2017Aspirant
Hi Dane. Sorry for the delayed response, I have been away from the office for 10 days. Unfortunately, your assumption was wrong. I have a site-site IPSec VPN link, where the connection parameters are prescribed by the other party. All I want to know is whether it is possible for devices on my primary LAN segment 192.168.2.* to access a remote service via the VPN, which has to terminate on 172.17.128.90?
- DaneADec 20, 2017NETGEAR Employee Retired
Thanks for the feedback. I apologize for I wrongly understood the network setup described from your initial post. Kindly post an image or screenshot of the detailed network setup you want to achieve.
DaneA
NETGEAR Community Team - DaneAJan 07, 2018NETGEAR Employee Retired
Just following up again. Let us know if you have further questions.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
