ivision
Jan 05, 2018Aspirant
VPN Client Activation ?
Hello I have just replaced my 500 SSD to a 1TB SSD. On boot Netgear VPN software says, it is not activated. When I try to activate it, I got an error as it is activated on an other pc, first I ha...
- Jan 08, 2018
I just got a feedback today. Your VPN Lite license key has been reset. Kindly check it. :)
If ever your concern has been resolved and you have no further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Jan 07, 2018NETGEAR Employee Retired
Hi ivision,
Kindly send me a private message and indicate the following:
a. The e-mail address that was associated to the VPN Client Lite license key when you have registered it before.
b. The VPN Client Lite license key.
DaneA
