a-hua's avatar
a-hua
Netgear VPN Client Active problem
Hi Support,
I have a FVG318v2 firewall with one license vpn client embedded. It is found that I can't active the vpn client on my new laptop because I forgot to remove it from my old laptop. Could you help to reset my activation status because my old laptop was sold?
A-Hua
  • a-hua,
    You should've sent it via private message so it will keep you private and the license key won't be taken away from you. I just edited your post.
    Let me try if we can now reset it.
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi a-hua,
    Welcome to our community!
    May you be able to send it to me via pm the license key and the email used in it?
    • a-hua's avatar
      a-hua
      Hi,
      License key: 553330-*****-****-*****
      Email: edward.999@********.com
      Thanks.
      A-Hua
      • JohnC_V's avatar
        JohnC_V
        a-hua,
ProSupport for Business
