gimnicher's avatar
gimnicher
VPN Client license key lost for SRX5308
I purchased the firewall in October of 2015 and am just now wanting to use the VPN features.  Unfortunately, I cannot locate the original CD containing the license key required to activate the five VPN Client software.  The serial # is XXXXXXXXXXX.  Will you/can you provide me the license key so that I can activate the VPN Client software?
  • JohnRo's avatar
    JohnRo
    Dec 21, 2016
    Hi gimnicher,
    That, I'm not sure. As it was not indicated on the key information, usually lite licenses are single. The best way to know is to install it and use the license. There was a "5U" code on the license code, so there's a chance it a 5-user license.
    Thanks,
  • Thank you so much for doing this.  One final question:  is the lite license key you sent me good for the original 5 copies or just for 1 copy?
    • JohnRo's avatar
      JohnRo
      NETGEAR Employee Retired
      Hi gimnicher,
      Thanks,
  • JohnRo's avatar
    JohnRo
    Hello gimnicher,
    Welcome to the community!
    I had to edit your post and removed the serial number. I have looked up the serial number you have provided and found out that it has a free VPN Lite license. I'll send you a PM for the details.
    Thanks,
ProSupport for Business
