FAYEZCHAHRSTAN
Oct 10, 2016Aspirant
VPN Client License
Hello
We have tried to install the VPN client from the CD, but i did not work.
When I loaded a newer version it asks me for a license which we dont have. I checked the CD and could not see an...
- Feb 28, 2017
Yes, I was able to register our FVS336Gv3 and had the license keys reset after opening an online case with support. Everyone was very helpful. I know this response is 4 months late but thanks again for your help.
DaneA
Oct 13, 2016NETGEAR Employee Retired
Hi FAYEZCHAHRSTAN,
I just want to follow-up on this.
DaneA
NETGEAR Community Team
FAYEZCHAHRSTAN
Oct 20, 2016Aspirant
Hi and sorry to delay.
It did npt solve the problem.
The software on the CD doesnot work with newer Windows and the one I dowlnoaded needs a Licensnr.
Moment 22 as we call it in Sweden.
Best Regards
Fayez
- DaneAOct 20, 2016NETGEAR Employee Retired
Hi FAYEZCHAHRSTAN,
It seems that what you have downloaded is the NETGEAR ProSAFE VPN Client Professional software. It would really require a license after the 30-day trial period. You may purchase the license key from any NETGEAR Authorized Reseller listed on this link.
DaneA
- DaneAOct 23, 2016NETGEAR Employee Retired
Hi FAYEZCHAHRSTAN,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
- dhetzellOct 26, 2016Tutor
I had a hard drive crash which was running the ProSafe® VPN Client Professional. I replaced the HD and reinstalled the software via a full backup. When attempting to run the VPN software, I was told that the license was already installed on another computer and that I would need to uninstall it from the old HD before it could be used. Since I can't uninstall it from the crashed HD, I have without success been attempting to contact Netgear tech support for advice. How can I get my license key reinstated? Who do I contact and how do I contact them???
We are using a Gigabit Dual WAN SSL VPN Firewall FVS336Gv3.
- DaneAOct 27, 2016NETGEAR Employee Retired
Hi dhetzell,
Welcome to the community! :)
I advise you to register the serial number of your FVS336Gv3 to your MyNETGEAR account. After you have registered it, kindly open an e-mail ticket under the FVS336Gv3. State what happened and do not forget to indicate the e-mail address you have used when you have registered your VPN license key before.
DaneA
