Ocampas
Oct 10, 2018Aspirant
VPN Client License
I cannot activate my software. Error 34.
Where is your chat portal??
- Oct 10, 2018
Hi Ocampas,
Welcome to our community! :)
It seems that you were having issues using the license that causes error 034. May I know what application are you using? Is it the Professional or the Client Lite? This error message pertains that the license key that you are using is not suitable to your installed software. If you are using the VPN lite, you may try to install the VPN Client Professional Software or do the other way around.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Ocampas
It is registered!
schumaku
Oct 10, 2018Guru - Experienced User
Great, so continue at that point as mentioned...
- OcampasOct 10, 2018Aspirant
I cannot find what you want me to find. your website takes me everywhere but where I need to be. I'm really confused.
- schumakuOct 10, 2018Guru - Experienced User
It's not my Web site - I'm not Netgear. Lack of a crystal ball, I have no idea what you see or does create confusion. Here is what get:
And because there is still mandatory moderation for in-line photos ... afraid it will take some time before you will be able to see these.
When I click "contact support" the options you are refering to do not appear. Only a blank spot where the options should be.
