RoebuckComms
Jul 09, 2019Aspirant
VPN Client Lite license key reset.
Hi Team, We have been experimenting with the VPN client for our hardware and due to a technical error had to reimage the machine, we are now unable to re-activate the VPN Client Lite software as the...
- Jul 11, 2019
We already reset the license key that you provided. May you be able to try installing the key?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnCarloV
NETGEAR Community Team
JohnC_V
Jul 10, 2019NETGEAR Employee Retired
Hi RoebuckComms,
Welcome to our community! :)
Please send me the license key via pm together with the e-mail address that is used to activate it.
JohnCarloV
JohnC_V
Jul 11, 2019NETGEAR Employee Retired
JohnCarloV
- RoebuckCommsJul 19, 2019Aspirant
Sorry for the late reply, Thank you for your help the software has been reregistered.
