dreamscape
Dec 09, 2016Aspirant
VPN client lite serial number
Hi, I have lost the serial number for my Netgear VPN client lite v5.1. I have been unable to locate it within the software's about dialogue box or Windows registry. The about baox says registered...
- Dec 11, 2016
Hi dreamscape,
Welcome to the community! :)
I believe you are referring to the VPN Lite license key, am I right? If ever I'm right, kindly open an online case with NETGEAR Support. State your concern and don't forget the e-mail address you have used when you have registered the VPN Lite license key before to your computer. A NETGEAR support expert will be responding to your query.
DaneA
NETGEAR Community Team
DaneA
Dec 11, 2016NETGEAR Employee Retired
Hi dreamscape,
DaneA
