njem
Jan 18, 2017Aspirant
VPN iPad ios10 to SRX5308
Before I beat my head against trying to get this VPN going and wonder why it won't work am I wasting my time? I find this article http://kb.netgear.com/25836/How-to-Setup-VPN-with-NETGEAR-Firewall-...
ChenX
Jan 19, 2017NETGEAR Expert
Hi njem
You should select the type to IPSec
Here is my config on IOS:
Type: IPSec
Description:Any
Server: SRX5308-WAN IP
Account: username (the user you added on the SRX5308)
Password: userpassword (the user's password you added on the SRX5308)
Use Certificate:OFF
Secret:the Pre-shared key on the SRX5308
PROXY: OFF
Regards
njem
Jan 23, 2017Aspirant
ChenX,
Thanks. Part way there. I think the way you set up the router end is different. On the ipad I made an IPSEC VPN connection (it offered IKE but I see yours is IPSEC).
It's offers these settings:
Server: outside IP of the office
(since I'm trying this from inside the office I've also tried using the LAN IP of the router)
Account: JoeUser
Password: (the password for the User, JoeUser on the router)
Use Certificate: off
GroupName: blank. I've also tried geardomain
Secret: (The preshared key made with the router VPN settings. I made this the same as the JoeUser password just to remove one variable.)
When the ipad tries to connect it says "VPN Connection: The VPN server did not respond."
On the router I made a user JoeUser of type "IPSEC VPN user". It says it's going to make them in user group "geardomain" but when I get back to the list of users it shows the Group column and Authentication Domain column as blank.
I made a VPN connection setup in the router using the VPN Wizard and chosing type "client". I suspect this did not create the right setup for this kind of conneciton. For one thing when I view VPN Status it doesn't even list it. What steps did you use to create the router side of the VPN?
Thanks.
