xmaster2002
Jan 03, 2013Aspirant
VPN IPsec work fine but i cant see any other PC
hi , my Problem : I connect my Notebook via VPN IPsec to my Netgear srx5308 ! I use IKE + Policies ( no modeConfig ). The connecttion work fine but i cant ping any other PC and also it isnt ...
xmaster2002
hi ,
i also try it with .0
same result !
if you use the wizard he fill it auto. with 192.168.1.1 ...
but i wasnt sure its correct .. thats the reason why i also try it with .0 !
any other idea !??
and thx for the tip with ... single polic. for each VLan !!
same result !
any other idea !??
- Feb 10, 2016Retired_Member
