xmaster2002
Jan 03, 2013Aspirant
VPN IPsec work fine but i cant see any other PC
hi , my Problem : I connect my Notebook via VPN IPsec to my Netgear srx5308 ! I use IKE + Policies ( no modeConfig ). The connecttion work fine but i cant ping any other PC and also it isnt ...
xmaster2002
hmm
you are sure !?
firewall are not installed on synology ds1812 and how i should do it on the srx5308 ... normally a ping after a VPN connection are online should be possible ! or not ? i actived ping ok from Lan and Wan at srx !
you are sure !?
- Feb 10, 2016Retired_Member
