xmaster2002
Jan 03, 2013Aspirant
VPN IPsec work fine but i cant see any other PC
hi , my Problem : I connect my Notebook via VPN IPsec to my Netgear srx5308 ! I use IKE + Policies ( no modeConfig ). The connecttion work fine but i cant ping any other PC and also it isnt ...
xmaster2002
Jan 05, 2013Aspirant
hmm .. i cant see any pic with ModeConfig !!!
i dont use it ! thats why normally it isnt possible that i post a ModeConfig screener !!!
PS:
mayb this helps also
Fri Jan 04 09:39:07 2013 (GMT +0100): [SRX5308] [IKE] INFO: IPsec-SA established: ESP/Tunnel
217.xxx.xx.xxx->109.xxx.xxx.xxx with spi=3320127859(0xc5e52173)
109.xxx.xxx.xxx->217.xxx.xxx.xxx with spi=226577000(0xd814a68)
Fri Jan 04 09:39:07 2013 (GMT +0100): [SRX5308] [IKE] INFO: No policy found, generating the policy :
172.xxx.xxx.xxx/32[0] 192.168.21.0/24[0] proto=any dir=in
Fri Jan 04 09:39:07 2013 (GMT +0100): [SRX5308] [IKE] INFO: Using IPsec SA configuration:
192.168.21.0/24<->0.0.0.0/0 from remote.com
Fri Jan 04 09:39:07 2013 (GMT +0100): [SRX5308] [IKE] INFO: Responding to new phase 2
negotiation: 217.xxx.xxx.xxx[0]<=>109.xxx.xxx.xxx[0]
Fri Jan 04 09:39:07 2013 (GMT +0100): [SRX5308] [IKE] INFO: Sending Informational Exchange: notify
payload[INITIAL-CONTACT]
Fri Jan 04 09:39:07 2013 (GMT +0100): [SRX5308] [IKE] INFO: ISAKMP-SA established for
217.xxx.xxx.xxx[500]-109.xxx.xxx.xxx[39120] with spi:5fc2131788210d2d:7d8804eeca0e4747
Fri Jan 04 09:39:06 2013 (GMT +0100): [SRX5308] [IKE] INFO: Received unknown Vendor ID
Fri Jan 04 09:39:06 2013 (GMT +0100): [SRX5308] [IKE] INFO: Received Vendor ID: DPD
PS:
- Feb 10, 2016Retired_Member
