xmaster2002
Jan 03, 2013Aspirant
VPN IPsec work fine but i cant see any other PC
hi , my Problem : I connect my Notebook via VPN IPsec to my Netgear srx5308 ! I use IKE + Policies ( no modeConfig ). The connecttion work fine but i cant ping any other PC and also it isnt ...
jmizoguchi
Jan 07, 2013Virtuoso
if you setup exactly the same as shrew/fvs336G case study other than use IP scheme the should all work
SRX side 192.168.1.x , Modeconfig 10.0.10.24 -49
Remote- make sure 192.168.1.x or 10.0.10.x lan subnet does not exist anywhere
with basic setup above from remote location you should able to access any 192.168.1x.
NOTE> I always put on my case study on first page as well that you did NOT want to use 192.168.1.x, 192.168.0.1, 10.0.0.0 as your primary LAN subnet on main VPN router to prevent conflict.
Also make sure you are using shrew on broadband (DSL , cable, T1, etc) but not mobile for initial testing. Using Cell Data brings additional issues
- Feb 10, 2016Retired_Member
