xmaster2002
Jan 03, 2013Aspirant
VPN IPsec work fine but i cant see any other PC
hi , my Problem : I connect my Notebook via VPN IPsec to my Netgear srx5308 ! I use IKE + Policies ( no modeConfig ). The connecttion work fine but i cant ping any other PC and also it isnt ...
jmizoguchi
Jan 07, 2013Virtuoso
You will find using VPN client outside of your network do should consider change it
- Feb 10, 2016Retired_Member
