xmaster2002
Jan 03, 2013Aspirant
VPN IPsec work fine but i cant see any other PC
hi , my Problem : I connect my Notebook via VPN IPsec to my Netgear srx5308 ! I use IKE + Policies ( no modeConfig ). The connecttion work fine but i cant ping any other PC and also it isnt ...
xmaster2002
Jan 09, 2013Aspirant
SOLVED
SRX5308 no ping after VPN conection to any VLan behind SRX5308
SRX5308 ip 192.168.1.1
VLan 1 : 192.168.1.x
DNS : 192.168.1.1
SubN.: 255.255.255.0
InterLan Routing active
DNS Proxy active
VLan 2 : 192.168.21.x
DNS : 192.168.21.1
DNS Proxy active
IKE
agressive
remote.com
local.com
AES-128
SHA-1
SA 28800
no auth.X
Group2
VPN Polic.
192.168.0.0
255.155.0.0
ANY ( remote )
Group2
SA 3600
This work fine !!!
IMPORTANT :
always shut down the SRX5308 ( full shutdown )
after changes !!!!
or in case that totaly nothing work = factory reset and start again !
or use a new firmeware !
That will help !
it work fine with shrew VPN and also netgear client ... current !
we will see its long time sable !
PS:
now .. i can have a look why i can ping and connect the devices but why i cant see and device at Windwos 7 Explorer -> Network overview !
( i think its a problem with the company, home and public network classes from Windows 7 )
I hope it will halp also others !!!
DNS : 192.168.1.1
DNS Proxy active
DNS : 192.168.21.1
DNS Proxy active
IKE
agressive
remote.com
local.com
AES-128
SHA-1
SA 28800
no auth.X
Group2
VPN Polic.
192.168.0.0
255.155.0.0
ANY ( remote )
Group2
SA 3600
This work fine !!!
IMPORTANT :
after changes !!!!
That will help !
PS:
- Feb 10, 2016Retired_Member
