xmaster2002
Jan 03, 2013Aspirant
VPN IPsec work fine but i cant see any other PC
hi ,
my Problem :
I connect my Notebook via VPN IPsec to my Netgear srx5308 !
I use IKE + Policies ( no modeConfig ).
The connecttion work fine but i cant ping any other PC and also it isnt possible to ping the SRX !
WAN1 217.xxx.xxx.xxx
VLan1
192.168.1.0 / 255.255.255.0
- SRX -> 192.168.1.1
VLan 2
192.168.21.0 / 255.255.255.0
- PC1 -> 192.168.21.100
- DS1812 -> 192.168.21.250
VPN-Client SHREW ( and also Netgear Client , same Situation)
- VPN-Client -> 172.xx.xx.2 (vodafone / iphone share )
( Active IPsec SA(s) .. )
( i can chnage it .. to self selcted IP 10.0.10.2 etc. but also no effect )
Why i cant ping any other device !?
any idea ... ?
PS:
more info
SRX - VPN Poilcies
Traffic Selection
192.168.1.1
255.255.255.0
Remote IP : ANY
FQDN : remote.com
my Problem :
VLan1
VLan 2
any idea ... ?
PS:
more info
SRX - VPN Poilcies
Traffic Selection
192.168.1.1
255.255.255.0
Remote IP : ANY
FQDN : remote.com
- jmizoguchiVirtuoso
VPN Polic.
192.168.0.0
255.155.0.0
ANY ( remote )
You made huge subnet which is okay.
You can make two tunnel for both 1.x and 21.x would more limited to only two subnets but it's your network.. - xmaster2002Aspirantyes i know !
lets see ... i will change it or not !
but i think the most interesst thing for the people they read here ..
are the fix the problem or to help them to solve the problem !
later they can do it more "complicated" if they have a first success !
I also have to config. mobile VPNs for this ... and and and ...
but step by step ....
Now i am first happy that it works now and it it wasnt my misstake !
prim. it was a Router problem of shutdown and boot .. also the new firmeware helps to solve it ! - jmizoguchiVirtuoso
it's not complicated deal just need to create additional policy but gain you only have two Lan subnet anyway so you do not have worried that much.
enjoy
- Feb 11, 2016Retired_Member
