vfandrea
Jul 10, 2017Aspirant
VPN logon fails
I have setup a VPN connection to be used from iOS devices (iOS Version 10), but I always receive a "login failed" error on my mobile device, even if user and password are correct (for sure). Connecti...
DaneA
Jul 13, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to access the articles and links I've shared and used them as your guide?
DaneA
NETGEAR Community Team
- vfandreaJul 13, 2017Aspirant
I already did what described inte the link you reported, I also used them to configure the firewall for VPN. But I had no success. To be honest after a reboot of the firewall i was able to connect, but after that still the same problem.
Finally I decided to use a different device as VPN Server.
