morrisonkena
Mar 20, 2017Aspirant
VPN MacOS client setup
Working to setup up a IPv4 Client-to-Gateway VPN tunnel for MacOS clients configuring the MacOS native VPN client (Network Settings, VPN Interface, Cisco IPSec type). It appears I have been successfu...
- May 21, 2017
I apologize for this is the only time I got back on this. Is your network setup as well as the settings on your FVS336Gv3 and MAC OS X Sierra the same as indicated on the article below?
Mac OS X VPN Client install with ProSAFE VPN Firewall/Router
DaneA
NETGEAR Community Team
DaneA
Mar 21, 2017NETGEAR Employee Retired
Hi morrisonkena,
Kindly answer the questions below:
a. Was it working fine before?
b. Does same problem occurs if you will established a VPN tunnel using other MACbook or iMAC?
c. What is the specific MAC OS are you using?
d. What is the current firmware of the FVS336Gv3?
Kindly post screenshots of the settings you have configured on the FVS336Gv3 and the MAC OS VPN client.
DaneA
morrisonkena
Mar 21, 2017Aspirant
Hi Dane,
Thank you for the reply.
I am setting this up for the first time, so I can't say it was working fine before. I have tried the VPN tunnel on only one MacBook Pro. But I plan to try today or tomorrow on an iOS device as well.
The current firemware of the FVS336Gv3 is 4.3.4-2, which I believe is current. S/N 3NJ252530021B .
The client environment is a MacBook Pro, 13", 2016, Four Thunderbolt 3 ports, 16 GB 2133 MhZ LPDDR3 memory, 1 TB SSD disk, 3.3 GHz Intel Core i7 processor, Intel Iris Graphics 550 w/ 1536 MB. The MacBook is running MacOS Sierra, 10.12.3.
Thank you and regards,
- Ken (morrisonkena)
