morrisonkena
Mar 20, 2017Aspirant
VPN MacOS client setup
Working to setup up a IPv4 Client-to-Gateway VPN tunnel for MacOS clients configuring the MacOS native VPN client (Network Settings, VPN Interface, Cisco IPSec type). It appears I have been successfu...
- May 21, 2017
I apologize for this is the only time I got back on this. Is your network setup as well as the settings on your FVS336Gv3 and MAC OS X Sierra the same as indicated on the article below?
Mac OS X VPN Client install with ProSAFE VPN Firewall/Router
DaneA
NETGEAR Community Team
DaneA
Mar 21, 2017NETGEAR Employee Retired
Hi morrisonkena,
Kindly answer the questions below:
a. Was it working fine before?
b. Does same problem occurs if you will established a VPN tunnel using other MACbook or iMAC?
c. What is the specific MAC OS are you using?
d. What is the current firmware of the FVS336Gv3?
Kindly post screenshots of the settings you have configured on the FVS336Gv3 and the MAC OS VPN client.
DaneA
DaneA
Apr 10, 2017NETGEAR Employee Retired
Kindly check if the VPN policy is configured to allow access to all of the network and not just the client. To check, on the web-GUI of the FVS336Gv3, go to VPN > IPSec VPN > VPN Policies then select the corresponding VPN policy then click Edit. The start IP Address in the Traffic Selection section should have 0 in the last octet, to allow access to the entire network.
Also, kindly ensure that the local IP address of the MacOS native VPN client is in a different LAN subnet than what is indicated on the LAN subnet of FVS336Gv3, if this is not possible you should use Mode Config. For example, if the existing LAN subnet of the FVS336Gv3 is on 192.168.1.x network, then the LAN IP address of the computer where you are using the MacOS native VPN client should be on a different LAN subnet such 10.10.10.x or 192.168.9.x network.
DaneA
