morrisonkena
Mar 20, 2017Aspirant
VPN MacOS client setup
Working to setup up a IPv4 Client-to-Gateway VPN tunnel for MacOS clients configuring the MacOS native VPN client (Network Settings, VPN Interface, Cisco IPSec type). It appears I have been successfu...
- May 21, 2017
I apologize for this is the only time I got back on this. Is your network setup as well as the settings on your FVS336Gv3 and MAC OS X Sierra the same as indicated on the article below?
Mac OS X VPN Client install with ProSAFE VPN Firewall/Router
DaneA
NETGEAR Community Team
morrisonkena
Mar 28, 2017Aspirant
Hi sqv,
I configured my FVS336Gv3 and my Mac's VPN client using a Netgear Application Notes document titled "How to Configure UTM with Apple OSX and iOS Devices for IPsec VPN", dated 2011. I can't recall how I stumbled upon this document but you could search for it.
As I said, I can connect from my Mac laptop to my FVS336Gv3 over the VPN, and I can send/receive email and web browse, but I cannot yet access LAN resources, such as my network storage. I am certain the solution is some configuration adjustment on the FVS336Gv3 (perhaps DNS resolution as you suggest) but I have not had the time to experiment and have not received any reply from Netgear or any other community member.
What I have not experienced is the timeouts you are seeing. The tunnel appears to stay up until I close it.
I have not yet configured iOS devices, as that is less critical to me that MacOS. Thank you for the KB article!
- Ken
DaneA
Apr 18, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to try the suggestions?
DaneA
