morrisonkena
Mar 20, 2017Aspirant
VPN MacOS client setup
Working to setup up a IPv4 Client-to-Gateway VPN tunnel for MacOS clients configuring the MacOS native VPN client (Network Settings, VPN Interface, Cisco IPSec type). It appears I have been successfu...
- May 21, 2017
I apologize for this is the only time I got back on this. Is your network setup as well as the settings on your FVS336Gv3 and MAC OS X Sierra the same as indicated on the article below?
Mac OS X VPN Client install with ProSAFE VPN Firewall/Router
DaneA
NETGEAR Community Team
morrisonkena
May 22, 2017Aspirant
DaneA,
Thank you for sharing this document, "Mac OS X VPN Client install with ProSAFE VPN Firewall/Router". I had not seen that in my searches.
Since I already had an IKE Policy set I did not use the VPN WIzard, but did edit my existing IKE Policy configuration to match that shown in the document. I then created a VPN Policy that matched that shown in the document. Then I downloaded and installed the IPSecuritas VPN client for Mac, configuring it also as shown in the document. Running the client from a different, outside network, testing the VPN connection back to my work network fronted by the ProSAFE FVS336Gv3 I could *not* connect.
I verified the settings and tried again. No luck. The error log generated by IPSecuritas shows me this message:
Connection KennyNetVPN is not started because of address collision between local (( "127.0.0.1/8", "::1/128", "fe80::1/64", "fe80::aede:48ff:fe00:1122/64", "fe80::47e:6959:af4c:25c5/64", "192.168.1.93/24", "fe80::4422:cdff:fe7e:f936/64", "fe80::dd35:9b1a:7cf6:2221/64", "fe80::7ab7:4e99:2578:c3df/64", "fe80::c0f:a40b:f157:9d6c/64", "fd28:7e35:d34b:5f8:c0f:a40b:f157:9d6c/64" )) and remote (( "192.168.1.0/24" )) networks
Any idea about this failure? Should I delete my policies completely and start over, using the wizard?
Thanks, Ken
DaneA
May 23, 2017NETGEAR Employee Retired
Kindly delete the existing IKE & VPN policies then start over use the VPN Wizard.
Let us know result.
DaneA
- morrisonkenaMay 23, 2017Aspirant
DaneA -
Did as you asked, deleted existing IKE and VPN policies then started over using the VPN Wizard. Verified all settings, including those of the IPSecuritas client. From an outside LAN I initiated a connection, the color indicator turned yellow, then red. Opening the log I noticed these errors:
TIme Severity Src Message
11:42:37 Error IKE phase 2 negotiation failed due to time up waiting for phase1. ESP 136.24.0.247[500]->10.10/10/115[510]
11:42:38 Error IKE phase 1 negotiation failed due to time up. fc325fd40062cb8c:0000000000000000
136.24.0.247 is the public IP address of my FVS336Gv3. 10.10.10.115 is my LAN address of the outside network from which I am connectted back to my home network. I can sent the full error log if you wish. Any ideas?
- Ken
- DaneAJun 06, 2017NETGEAR Employee Retired
Thanks for the update. I apologize for the late response.
I found another article online which is a bit different to the first one I've shared with regard to some settings configured. Kindly access it below and try to follow the steps:
IP Securitas Os X – Netgear FVS336G VPN Settings
Kindly delete the existing IKE & VPN policies then start over again. Let us know the result.
DaneA
- genesearchJun 22, 2017Aspirant
Ken
About a year ago, I got exact same error message as you, when connecting to a VPN created by Netgear Support just for me to test with
"setup a IKE policy with mode config enabled in our laboratory"
my error message was:
Error IKE phase2 negotiation failed due to time up waiting for phase1. ESP 124.83.33.11[0]->192.168.1.198[0]
Netgear support are telling me that they received no connection attempt from my network. It was at that point I have up on the whole idea of setting up a VPN and tossed it into the too hard basket.
Did you ever get it working?
- morrisonkenaJun 23, 2017Aspirant
DaneA,
Thank you for the additional article with alternate settings. I did try those alternate settings, but also without sucess. The two articles had variations on similiar settings, which has suggested to me to play around a bit more with those settings, in hope of finding a combination that works. I'll update this thread with any successful findings.
- Ken
genesearch,
DaneA, on this thread, has provided references to two articles purporting to have the configuration deteils I require. However I have tried both configuration settings sets without success. The similiarity of the settings between the two articles has me believig that I am close, so I will "play" with variations on these settings to see if I can break through. I will update the thread with news of any breaktrough. I'll also drop you a brief note as well. But then again, if after experimenting, I might also have need for the "too hard" bucket!
Still, given the growing popularlity of Macs, I find Netgears weak support for that platform baffling. There should be good, tested, instructions for setting up this VPN on the FVS336G ("with SSL and IPSec VPN") using MacOS. There also shoud be a MacOS version of Netgear Smart Control Center. One can hope NetGear comes to recognize this market.
- Ken
- genesearchJun 26, 2017Aspirant
Ken
I have since got the VPN working using the above instructions and it worked, however I didnt do anything different than last time.
Since I had updated both the Netgear router firmware and using Updated version of Ipsecuritas, i can only assume that there was something wrong with older software. Especially that I was gettin the same errors connecteding to the Netgear supports test VPN they created in their lab.
